Lamps by Post - For all your lighting needs
Thread Tools
Old 13-07-2006   #1
Track Rod Ends... Help Needed!
Hi guys, is there a how to on the forum to fit new track rod ends at all? Cant see any on the site and I have this lovely job to do at the weekend before i put the long and expensive project car in for its MOT. Its a Mk1 although i think the process is the same for the mk1 and mk2.
Again, any help will be greatfully recieved.
Patch124 is offline Reply With Quote Quote
Old 13-07-2006   #2
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: Track Rod Ends... Help Needed!
You need a pair of spanners, one to fit the end of the track rod end, and the other to fit the locking nut. You then need a ball joint opener, preferably a screw one rather than a hammer in one (less stress on the steering rack).
Basically its jack up and support.
Wheel off.
Nut off where track rod end bolts to hub carrier.
Hold track rod end with one spanner and undolocking nut - you may need to hold the track rod itself with spanner/molegrips - undo locking nut 1 turn only.
Hold track rod and unwind track rod end.
Wind on new track rod end upto locking nut, fiddle until you've locked it in the same place as the one you took off.
Pop the end into the hub carrier and wind on the nut, should pull the pin in, careful not to send the pin spinning in the end or you'll never get it tightened (or undone again).
Replace wheel.
Remove supports and lower.
I then usually take it for a drive then into a garage to have the tracking set.
Hope this is useful and correct.
Drives: Alfa 147 Lusso , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 14-07-2006   #3
Further to my query - i found this link that may be of help to anyone else who needs to do this job.
[URL="http://www.fiatforum.com/panda-guides/45629-replacing-tie-rod.html?garpg=4"]
Thread Tools
(T) *HELP* Track rod removal Ali P Bravo / Brava 3 10-08-2010 19:19
(T) Track Rod Nut paul_treg Cinquecento / Seicento 8 15-06-2005 22:10
(T) Track Rod Ends Warful Cinquecento / Seicento 4 15-06-2005 11:41
(G) Track Rod Ends Giacosa Panda (Classic) 1 24-02-2005 19:53
(T) Track rod end arseofbox Cinquecento / Seicento 18 22-07-2004 22:20
