As far as I understand it handles a lot of the electronical work that used to be in the ECU. As cars have become more complex a separate ECU has been fitted to carry out things like mpg display, airbag control (i think) etc.
Controls timer based controls (interior light/heated screens etc) and locking/stores key & remotes etc also converts CAN line systems from B to C etc if fitted....loads of stuff,thats why its 'multifunctional'
instead of having a zillion wires and relays about the underside of the dashboard there is one core harness that links everything up as simply and using as little wires as possible, then the computer puts them all togther, computes the signals then sends out again, basically all the dash is reliant on it rather than a network of switchs and wires and relays etc, which in real terms actually cost more than a body computer, however fiat being greedy buggers will charge you a grand or so
