Hiya i was driving today and i needed to wash the window instead of water there was really gloopy slime.why is this?can i drain the resovoir of its window wash?
under drivers side wing. have you ever topped the water up ?? doesn sounds likeit if you dont know were it is. maybe worth just topiing up wioth water and running it thourgh
ah well if you can remove the bottle and drain ,good flush out with plain water.replace the bottle,fill with plain water and pump through the system to clear the pipes
Lot of hassle to remove the bottle. Either take the n/s wing off or if you fancy a struggle i believe it can be done by removing the wheel and wheel arch liner but im not sure on the latter!
to get the bottle out you've got to remove arch liner and road wheel or wing (or both ideally), without taking the wing off space is EXTREMLEY limited, trying to get it out WILL result in cut and bloodied hands and several hours with your wrench going about 15degrees then back and click, then 15degrees then back then click, it really takes the biscuit, and the bolts are fairly stiff and very long (longer than what they need to be for 2.5kilos of water
