Hi!
I own Fiat Punto 1.9 JTD (year 2000)
Few days ago both head lights stopped working at the same time.
- I checked light fuses under the steering wheel. They're fine.
- I checked the bulbs. They're also fine.
- I checked the voltage on the fuses. It's 12 V when light switch is ON.
So this must mean that light switch and relay are also good.
- But when I checked the voltage on the bulbs it was allways 0 V.
Is there something between light fuses and light bulbs which may be broken (except wires)?
If it's only wires how can I find both ends of the wire so I can check it?
Is there some wiring diagram available on the net?
Thanks in advance!
Thanks in advance!
