Technical Trolley Jack query
Can someone please point out the correct area for a trolley jack to lift the front of a Punto mk2 on this diagram as explained in the owners manual
Would I be correct in assuming the gearbox/differential referred to is the bit circled in red?
personally when i use a trolley jack i jack it from the points the standard fiat jack would go on just behind the front wheel and in front of the rear wheel, never had any issues there!
Looking at your pic.....just above 1a..1b.. on the bottom of the transmission block....with a chunk of wood....very similar to mk1 underneath from that photo....someone will agree or disagree..lol
I jack up my mk1 punto using the bit circled in red with a chunk of wood inbetween, as it says in my Haynes...
