C catchy New member Joined Dec 6, 2005 Messages 24 Points 13 Dec 7, 2005 #1 Anyone know the socket size of the punto wheel nut at the front. Otherwise reffered to as the driveshaft nut, hub nut. Its a castellated nut.
1 123monty New member Joined Sep 23, 2011 Messages 1 Points 0 Sep 25, 2011 #2 what torque did you use to tighten Fiat Punto 32mm hub nut?
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Sep 25, 2011 #3 123monty said: what torque did you use to tighten Fiat Punto 32mm hub nut? Click to expand... The figure is in the FAQs, either for the Cinq/Sei or Punto. You won't be able to reach the required torque with a standard torque wrench, though.
