FIAT Auto Specialist Team
Thread Tools
Old 1 Week Ago   #1
No hope with the punto
Well I think it's time to cut my loses. Bought it cheap for daughter to learn in and now she has passed. But with the clunking noise still there after changing almost all the front end.
Top mounts. Springs. Struts. Track rod arms. Wishbones. Both driver shafts. Front disk and pads and out roll bar bushes. It still won't stop knocking.
I won't be happy to allow her to drive by her self knowing it's still doing it.
So I think it's time to give it a good wash in and out and sell. Shame as I liked it and it's a really clean car.
2003 1.2 8v sporting 69k with around 8months mot.
onthejazz is offline Reply With Quote Quote
Old 1 Week Ago   #2
Re: No hope with the punto
Recently had both front shocks and springs plus lower arms fitted...and had a clunking noise when I turned the steering or went over speed bumps, it didnt do it all the time. After some investigation i spotted that the front passenger side spring was contacting the inside of the suspension turret. Garage has now replaced both top mounts(gree of charge to me), but as someone has pointed out the springs have to fit a specific way due to being banana shaped.
Spring is no longer contacting and noise has gone.
http://www.fiatforum.com/punto-ii/45...t-springs.html
Scudmonkey is offline Reply With Quote Quote
Old 1 Week Ago   #3
Cheers for that,
We checked it all again yesterday, no rubbing on strut or body work
Old 1 Week Ago   #4
have you checked the Gearbox/Engine Mounts ? That can also produce a knocking noise.
Also worth checking the back end too, as Exhaust knocks against rear suspension if not quite lined up correctly on these cars. Also worth checking the rear shocks as that can also make knocking noise.
Old 1 Week Ago   #5
Quote Originally Posted by Scudmonkey View Post
I just checking price for gearbox/engine mounts now, if they aren't to much will just buy and replace them.
Was thinking about rear shocks but the sound really sounds like its drivers fronts
Old 1 Week Ago   #6
varesecrazy has donated!
Quote Originally Posted by onthejazz View Post
aim it at a few small speed humps.. then you should know which wheel / corner to look at
had all this with my marea.. ,
keeps passing MOT's.. but still annoying
Old 1 Week Ago   #7
99.9% sure its the drivers side.
Didn't do it when we bought it, but 4days after owning it, it started.
so while looking at the state of play everything was, just thought might as well replace the lot lol, when parts don't cost much.
Don't really want to take it to another garage to pay them to strip it all down and check everything we have checked before.
Only thing we haven't changed is the inner anti roll bar bushes, new full bar 110 that will be the most expense part I will buy for it. But don't want to if it doesn't fit it.
Old 1 Week Ago   #8
atom0007 has donated!
Check the exhaust. Sometimes the prongs on the backbox can hit the inside of the bumper. Try pulling the back box (when it's cool) towards the back bumper to see if there is clearance. This was one annoying difficult to find knock for me
Another one was the handbrake cable hitting inside the wheel, after its mount to the trailing arm dissolved through rust.
Costs nothing to check these ones. Good luck
atom0007 is offline Reply With Quote Quote
Old 1 Week Ago   #9
Finland
The first part of the exhaust as it comes out the engine should have a fiat. bracket fixed to the bottom of the gearbox. Hard to make your own one so often they are not replaced for a new exhaust. You then have the whole exhaust moving around when it should just be the parts under the driver that move independant of the engine.
judderbar is offline Reply With Quote Quote
Old 1 Week Ago   #10
Cheers for that info.
I will have a quick google for what the bracket looks likes as am unsure if the down pipe has been replaced. I know it needs to be lol
Thread Tools
(S) Hope you can tell me what colour my punto is? richous05 Punto (Mk1) 3 16-05-2011 22:52
(G) V6 Punto, is there any hope? StoneNewt Punto (Mk2/2b) 17 14-07-2006 10:29
(T) Punto GT - Fixed (I hope!) pkelly23 Punto (Mk1) 8 29-01-2006 20:22
