Thread Tools
Old 1 Week Ago   #1
Handbrake light
2002 punto jtd has the following issue that from parked the speedo works until after a similair amount of time the speedo stops working as the handbrake warning light comes on..
The amount of time until it happens varies but it is the same scenario.
The things I've tried are adjusting the handbrake cable, topping up the fluid.
On on an odd occasion the speedo has come on intermittently while driving..
Bit odd it has a strut brace but it was already doing this before fitment.
If this rings a bell with anyone I'd be much obliged if you can shed some light.
Thanks josh.
dubsential is offline Reply With Quote Quote
Old 1 Week Ago   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Handbrake light
Quote Originally Posted by dubsential View Post
Thanks josh.
Do you have abs or u non abs?
As this will provide a big clue
Abs cars are all done via abs pump and sensors
Non abs are Speedo sensor driven,
For handbrake light - ensure brake fluid isnt dangerously low
Ziggu
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 1 Week Ago   #3
Quote Originally Posted by Ziggy122 View Post
Ziggu
Hi thanks for your reply.. It is an abs model I don't have a abs light on though and multiecu scan isn't showing a fault with the abs..
This started when the car dropped on to the rollers at mot station.. However the handbrake cables and shoes were renewed for the mot at this time.
I'm stumped as for a mile at most the speedo works.
The fluid is OK.
Cheers hope you can help.
Literally handbrake light comes on speedo needle drops.
Old 1 Week Ago   #4
Re: Handbrake light
since the rear shoes and handbrake cable were changed i'd suspect something with the ABS causing the issue.
I'm guessing it was all working fine before those were changed, so it would be the most likely culprit
Scudmonkey is offline Reply With Quote Quote
Old 1 Week Ago   #5
Quote Originally Posted by Scudmonkey View Post
Yeah I can certainly see that logic thinking about it the drums I swapped from a mk1 my mate was scrapping...
Only thing is on the way to the mot it was working for 5 miles.
And the speedo is intermittent but always works from a restart for roughly the same amount of time.... Bit odd and bloody frustrating.
Oh dear I also swapped the hubs so im guessing that's the problem.. If anyone knows if the drums are any different on abs models please chime in..
So much for some free low milage replacements.
Also I don't understand why the only error I've got is vehicle speed sensor missing signal and no abs light.
Likes multipete liked this post
Old 1 Week Ago   #6
Re: Handbrake light
Does the abs light come on during self test? And then goes off?
As for mk1 hubs - they were mostly non abs, as a result there is no tone rings on the hubs
Probably fine if fitted to a non abs mk2, but since mk1 usually didnt id be checking hubs actually align up correctly for the sensor pickup and the pickup ring is present in tact
If there missing then no speed signal can be gained for the wheels
Swap back or refit correct parts
Mk1 and mk2 are different cars
Mk2 and mk2b have alot more interchangeable
Ziggy
Meet Bumble-Bee
Old 6 Days Ago   #7
Ziggy
OK thanks ziggy yes it's a schoolboy error on my behalf.. The punto they came off wasn't abs so that will be the problem..
Do you know if the drums would also be posing an issue, is there a difference as I used the mk1 drums besides the fact they aren't abs what I mean is does the abs use the drum for any data as such.
No abs light on self test so that will be blanked then... Not by me
I can confirm you can feel the abs kick in
Under heavier braking.
Thread Tools
Doblo ABS warning light and handbrake light melville1967 Newbie Central 2 16-10-2015 07:35
(T) handbrake light/abs light needham18 Punto (Mk2/2b) 1 13-05-2015 22:34
(T) Is the HAndbrake light also a warning light? fatty Cinquecento / Seicento 9 17-05-2008 08:48
(T) handbrake light greenstarvaz Punto (Mk2/2b) 2 28-01-2007 16:40
Handbrake light Simon FIAT Boo Archives 1 09-03-2001 13:22
