Thread Tools
Old 2 Weeks Ago   #16
Slovenia
Re: air filter mod
Quote Originally Posted by Ziggy122 View Post
One step at a time
If u have a good run cleaning and its easily done - do it
If ur having a bad day - take ur time and do what you can
Ziggy
good thinking, i only asked because i saw alot of pics of dirty manifolds aswell, since thats conected i dont wna do the whole injection system just to than be setbacked for not cleaning the manifold aswell, ill see how it goes yeah everything to egr valve seems easy, wont even need to lift the car up, i saw i can take out the intercooler from below the car aswell so wont need to take out the bumper, but at egr and manifold things start to get harder. i start tomorow got 3 free days hopfully that will be enough.
question still stands, can i clean these things with gasoline ?
Likes AndyRKett liked this post
Jaka Cvajnar is offline Reply With Quote Quote
Old 2 Weeks Ago   #17
Re: air filter mod
Don't use petrol, it's too volitile and dangerous to use as a cleaning agent.
You could use diesel, would likely work, but remember you'll have to clean it up afterwards and dispose of it safely, not just down a drain where it could do some real damage.
And remember that these solvents will dissolve bitumen used in domestic driveways leading to degradation of the surface or potholes
AndyRKett is offline Reply With Quote Quote
Old 2 Weeks Ago   #18
Slovenia
Quote Originally Posted by AndyRKett View Post
Hmm. Well i read alot clean with petrol.. the problem is idk where i could find so much cleaning agent here.. thats why i thought petrol is the most convinient method. Ur thought about cleaning manifold aswell?
after i clean all this, it will make a differance right? but after that i could also add an induction kit like https://www.dcperformance.co.uk/chea...sassh7080.html and it would be even better?
Old 2 Weeks Ago   #19
Slovenia
Re: air filter mod
hose from torbo to intercooler down and cleaned, intercooler down and cleaned, hose from intercooler to egr down and cleaned... this egr and manifold on 1.3 are retarded... all mashed together .. cant find a single pic of a manifold online for referance.. gona go in blind wish me luck
Old 2 Weeks Ago   #20
Re: air filter mod
Quote Originally Posted by Jaka Cvajnar View Post
I refer you to my previous comment, it's a 70hp 1.3 diesel, it's already forced induction so a fancy pipe and filter is not going to make a shred of difference.
For all my Punto and Punto Grande Instructional Videos Visit My YouTube page
MyNew Website is now at www.puntohowto.com
Or check out the Facebook Punto page
Old 2 Weeks Ago   #21
Slovenia
Re: air filter mod
i do get that. as stated at start the problem is witt me not getting enough air to the added fuel from chip, so i get wasted fuel and wasted power.. im only asking if this kit will supply more air not more power, i need more air so i can turn on my chip and that will combine into power. or not?
btw, i gave up on egr and manifold, imposible for me... maybe id get them down somehow but getting them back on would be a dizaster. gona try that egr spray cleaner and hope it cleans it abit.. worth a try.
i also disconected or found a connector in the engine bay that i cant locate the other half LOL... so i started it and all work fine but u never know what that connection is for. gona have to post tomorow if anyone with a 1.3 can find where my missing link is haha
Old 1 Week Ago   #22
Re: air filter mod
I think it's more likely that the chip is not matched to the engine properly and this is the problem with a generic plug in box
You can only get a finite amount of air in as the turbo waste gate will open and dump the excess.
The turbo can only provide a certain amount of compressive force, based on the amount of gasses passing out of the exhaust.
Adding a different air filter will not change any of this, and this is the last time I'm going to say it, because it's getting silly now.
If you don't want to listen fine, go waste your money and bolt whatever you want on.
Old 1 Week Ago   #23
Slovenia
Re: air filter mod
well cleaning the intake + egr and manifold helped abit, not completly.
one last question... if i take the filter off and put hand before the maf senzor and someone revs the engine i feel alot more suction than with the filterbox on and havine a hand in the entrance there. thats why i asked. but ok..
btw i used crc egr cleaner/(spray) to clean egr and manifold trough the intake, i know this isnt even close to dissasembly and acual cleaning but there was no other way, anyways after some time of the spraying at engine on 2k rpm, the engine started give out noise, nothing specific just like if air is going out trough some hole that isnt ment for that, on the left side of the engine. it didnt do that at start. will check if the noise is still there tomorow. but it was really waird and i stopped spraying, no leakage or anything just unusual air sound
Old 1 Week Ago   #24
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: air filter mod
The "Chip" you have fitted is just an over fuelling device. It is a little bit more advanced than the ones with just a resistor in that you can select up to 4 settings. Where is it connected to?
A remap will always be better.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 1 Week Ago   #25
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: air filter mod
I looked a bit more into Italan Speed website and terms and conditions. I note the following
There is no contact address or company registration number on the Italain Speed website.
The first condition is "The products intended for use in automotive (chiptuning for gasoline or diesel and systems for the elaboration, electronics, of the engines) can be used only and exclusively for racing use (sports) in closed circuits, private circuits or private areas." in otherwords not legal for road use. Nowhere on their homepage or product descriptions do they mention race use or that it's not road legal.
Despite their comments about remapping damaging engines and having no warranty, their warranty says "The company assumes no responsibility for any damage caused to persons and / or property, caused by the products purchased" so if the engine blows up they don't care unless their unit was faulty (who can tell?).
To return the goods (your right under EU law) you first have to send them a registered letter. See comment above on no address. Email is not acceptable to them.
For my car (1.9 16V mJTD Croma) they claim a 30% increase in power along with a 21% reduction in fuel consumption. This is clearly contradictory and probably impossible. Trouble is if it increases the fuel pressure, the consumption reported by the trip computer will be less as it assumes correct fuel pressure (fuel flow is calculated from injector design flow rate and open time). From the install description https://www.italianspeed.eu/en/easy-installation-2-c it clearly just messes with the fuel pressure signal causing over fuelling.
The parent company are Extremengineering Srl who are behind other front companies like Drake box.
Robert G8RPI.
Likes andydiver liked this post
Old 1 Week Ago   #26
Slovenia
Re: air filter mod
Quote Originally Posted by g8rpi View Post
Dispite their comments about remapping damaging engines and having no warranty, their warranty says "The company assumes no responsibility for any damage caused to persons and / or property, caused by the products purchased" so if the engine blows up they don't care unless their unit was faulty (who can tell?).
For my car (1.9 16V mJTD Croma) they claim a 30% increase in power along with a 21% reduction in fuel consumptom. This is clearly contradictory and probably impossible. Trouble is if it increases the fuel pressure, the consumption reported by the trip computer will be less as it assumes correct fuel pressure (fuel flow is calculated from injector design flow rate and open time). From the install description https://www.italianspeed.eu/en/easy-installation-2-c it clearly just messes with the fuel pressure signal causing over fuelling.
The parent company are Extremengineering Srl who are behind other front compnies like Drake box.
Robert G8RPI.
their addres is stated in terms of service section under number 5.
so i bought a usless chip? shauld i remove it?. i know a remap is better but cost more and everythig. i wanted a cheap easy bump up, i know the car doesnt have 100hp like they state but its abit better anyways.
what would u recomomend? dich the chip? which chip manufacturer do u recomend?
i checked alot of revievs and videos af the chip. i do belive the chipe does make some differance in power, for me it was quite noticable, for the bare 90€ u cant expect to get the best thing.. but performance/value wise the italianspeed is one of best.i talked alot with them over email they helped alot. but i do belive every chip manufacturer has the "we arent responsible for any damage" in their terms of service.
Old 1 Week Ago   #27
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: air filter mod
I missed that address. It's not in the contacts section though and is not for Italian Speed.
I would not recommend any of the fuelling modification boxes. They are not "Chips" or Chip tuning" in the established sense. Proper chip tuning is a type of re-map for ECU's where the map is in PROM and the memory ic "chip" has to be replaced. Modern ECUs use re-programmable memory (EEPROM or Flash) so the chip is not changed. The fueeling modifiction box makers have mis-approprated the term to make their products sound high tech. Some do have chips, op-amps or possibly even microprocessors, but many do not. You can't tell with your box as it is potted i.e. filled with resin so you can't take it apart or see what is inside.
Increaing fuel pressure, which is what these boxes do, puts strain on the fuel pump and other components and can lead to all sorts of issues. If you have a DPF the overfuelling will cause it to block more often and may even damage it and or the catalyst.
They are just a bodge that makes your car illegal to use on the road and invalidates your insurance.
Robert G8RPI.
Old 1 Week Ago   #28
Slovenia
Re: air filter mod
Robert G8RPI.
understandable, so its a cheap wnb powergain, it still gives some power, i also am afraid of the side efects if it is as bad as u say.. it is what it is now.. gona roll with it until the car dies anyways
for fun, im gona email the italianspeed and ask them if i can see whats inside the acual chip(things we cant see.) but as u say, my can maybe be somekind of chip, but its more liky fueling box?
how to know if a chip is legit than? higher price?
Old 1 Week Ago   #29
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: air filter mod
No, price is no indication of quality. Some sellers will price high just because buyers associate price with quality. A shiny box and slick website means nothing. Any tuning box that just plugs into a fuel pressure, MAF or MAP sensor is a fuelling bodge.
The only sensible option is a re-map.
Robert G8RPI.
Old 1 Week Ago   #30
Slovenia
Re: air filter mod
Robert G8RPI.
my conects to common rail, is that the fuel pressure ur reffering to?, a legit chip shauld be connected to egr or what?
will check into remap. but i think im done with the car as it is. still remap prices r high if not mistaken... maybe next car ill take more serious tuning, this one is more of a ricer anyways
Thread Tools
Fiat 500 1.4 sport wanting to increase air intake with out getting a new air filter courtss Tuning 0 04-01-2016 18:37
(Tu) How to change stock air filter to K&N air filter? MatthewShikari Grande Punto 8 01-03-2014 12:38
(Tu) changing standerd air filter for a aftermarket air filter punto2011 Punto (Mk2/2b) 3 04-03-2011 10:22
Any Pix of Custom Air Intake / Modified Air Filter Box ? Boorock FIAT Boo Archives 4 16-12-2003 14:58
ive replaced the standard fiat air filter with a green air filter- need help! Anonymous FIAT Boo Archives 5 01-07-2003 00:24
