Thread Tools
Old 4 Weeks Ago   #1
no ecu light ?
H i all , my son has just bought a 2004 1.2 8v punto thats developed an issue when idling it is a little rough we have serviced it but no change , plugs are sooted , pluged a diagnostic in and it showed p0141 which we believe to be the down stream lambda sensor . we found the sensor to be loose so took it out cleaned it and replaced it but did not remove the fault so will get a new one to hopefully sort the problem . We did notice that the ecu light is not working when ignition is switched on so leads me to think someone has disconected it to hide our initial fault , i believe the ecu light is an led soldered in so is there an easier way the light can of been disabled ? thanks for reading Russ
RUSSBUS is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
Mexico
Re: no ecu light ?
lambdas on these are same for bank 1 and 2 so you might find it easier replacing by good second hand one to removing a front one as they usually come out
copy parts cheap in white bowes are best left alone
a new lambda quality might be 80
you cant really clean a lambda
with regard the management light yes im pretty sure its an led
to add the second lambda records that the engine is not running at optimum Stoichiometric and therefore is a guide you have a problem
s and b is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
Re: no ecu light ?
Thanks for info i will post how we get on
Old 4 Weeks Ago   #4
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: no ecu light ?
If you have MES (multi ecu scan) there is an option to test the ECU light hahahaha
Im pretty sure tho - if an LED fails, the dash on self test should display display Error or words to the effect
LED's can and do fail, very rarly in the dash like
so it may have been tapped over on the board itself vs actually been removed
If you do decide to take the dash apart
Watch out - the Clear facia bit clips are EXTREMELY BRITTLE
they Do and WILL snap
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
Re: no ecu light ?
Hi , we put a new sensor down stream but made no difference so replaced the up stream one with the one that was down stream and it now runs a lot better after a 10 mile trip . It does still run a little rough when idling occasionally and some times the revs jump up a little so may be after a few more miles it may clear , time will tell thanks for the input to this thread by members Russ
Old 2 Weeks Ago   #6
Re: no ecu light ?
Looks like the fault is still present , if car has a 10 mile run its fine but go back to 1to 2 mile journeys it idles rough and mpg drops to around 20 , after reading posts on here and the net it looks more likely a new catalytic converter is needed so probably will try this next
Old 2 Weeks Ago   #7
flisko's Avatar
flisko has donated!
Re: no ecu light ?
new cat?
just go to mot first to measure gasses
flisko is offline Reply With Quote Quote
Old 2 Weeks Ago   #8
Re: no ecu light ?
did not think to go to mot station , to late now i fitted it yesterday and after a short run all seems ok no rough idle and feels to have better response from the accerator , fingers crossed , thanks again for replys will keep post updated
Old 6 Days Ago   #9
Re: no ecu light ?
A week on and car seems to be running ok now thanks for posts Russ
Old 6 Days Ago   #10
Re: no ecu light ?
Did you get the dash light to work ?
Scudmonkey is offline Reply With Quote Quote
Old 2 Hours Ago   #11
Re: no ecu light ?
No it still dont work but showing no faults on diagnostic so not looked into that any further , the diagnostic reader did not show a faulty or none working ecu light I dont fancy stripping the dash down as it looks a delicate job and knowing my look could cause more problems
Thread Tools
(T) ecu light again richib Punto (Mk2/2b) 13 08-01-2011 12:52
(T) ecu light? sportyjay Punto (Mk2/2b) 4 15-12-2010 23:48
(T) ECU light killyourmama Cinquecento / Seicento 6 05-04-2010 13:22
(T) ecu light on :s MickeyBravo Bravo / Brava 4 04-11-2008 23:01
(T) ecu light! m_aver_ick Punto (Mk2/2b) 7 06-11-2005 18:17
