Thread Tools
Old 3 Weeks Ago   #1
Brake fluid
Hi hope we are all having a good weekend.
I was wondering if someone could help me. It seems since having brake pads changed about 4 months ago that my brake fluid seems to go down quickly. Since having them done I have had to top up my fluid twice ( last being today )
It has gone from top line to half between Max and min in two months. Breaking is normal. apart from rarely sounding like rubbing as stopping.
Is there anything I should look at to try work out what the fault is?
Many thanks
kfreeth83 is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Brake fluid
Obviously you are looking for a leak... Check the system. All pipework/cylinders /unions.
jimboy is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Re: Brake fluid
New to all this so wanted to check first. Thought leak would cause problem to brake use.
Thanks for replying
Old 3 Weeks Ago   #4
Mexico
Re: Brake fluid
check clutch slave cylinder ,these often leak and get their fluid from brake master cylinder,if no leak here check under car rear for failed rear brake cylinders by looking for wet rear plates or look on axle beam drivers side for a leaking constipation valve,remember a leak can turn into a gush so needs sorting yesterday
front hoses chaff through too.ask ziggy
s and b is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
Re: Brake fluid
Grateful of the input will check
Old 3 Weeks Ago   #6
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Brake fluid
Oh yes.... check them flexis for damage
U dont want one popping on you....
As for wet back plates
Whip them drums off... ull have a clear visual on how bad if its the rear cylinder the leak is
A full inspection is needed, as loss of fluid is either a sign of a leak of heavily worn components
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 3 Weeks Ago   #7
Re: Brake fluid
Thanks for replying. Am thinking to take it to garage had pads done as it seems to be since they had their hands on it and check their work if not I'll go to my normal garage for a break check .
Old 3 Weeks Ago   #8
Re: Brake fluid
Sounds like a lot to check and being brakes best leave to someone else.
Old 3 Weeks Ago   #9
Re: Brake fluid
Whilst it may sound like a lot to check, any leak is obvious as the components around it will look wet
Scudmonkey is offline Reply With Quote Quote
Old 3 Weeks Ago   #10
Re: Brake fluid
Looks like we're all going round in circles here. Same advice given in each post. Simple visual check is all it takes.
Old 3 Weeks Ago   #11
Re: Brake fluid
Sorry if was duplicate post but being new to this DIY car stuff and don't know break set up. So was looking for advice on places to look for to learn.
After check garage have pointed out it's the compensator.
Old 3 Weeks Ago   #12
Re: Brake fluid
Quote Originally Posted by kfreeth83 View Post
The load level sensor on the rear axle
The more weight on the back - opens the valve up allowing more fluid to the rear drums (less of a restriction)
Meaning there is greater effort coming from the rear brakes
These aint cheap! And if the pipes dont come out easily in one piece, itll very quickly become a nightmare job....
Itll require a full arse bleed too, so if they drum cylinders are seized solid its now very messy place to be.....
Ziggy
Meet Bumble-Bee
Old 3 Weeks Ago   #13
Re: Brake fluid
The only place the garage could find one is fiat and price was about 170 just for part.
Old 3 Weeks Ago   #14
Re: Brake fluid
RzxxZzx
Old 3 Weeks Ago   #15
Mexico
Re: Brake fluid
last one i bought was from andrew pages for 80
Thread Tools
(G) Panda Multijet Diesel Brake Discs and Pads and Brake Fluid Change ytareh Panda 0 24-06-2014 00:39
(T) Brake fluid spraying out when I press brake pedal Firthy Punto (Mk2/2b) 50 10-06-2013 22:26
(T) Brake Fluid Reservoir + Brake Fluid Question oagra Punto (Mk2/2b) 2 21-10-2008 13:13
(T) My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do? keepinitcriss Punto (Mk2/2b) 5 02-04-2007 18:30
stupid question - brake fluid/steering fluid dave FIAT Boo Archives 2 15-09-2003 12:28
