Thread Tools
Old 3 Weeks Ago   #16
Re: Brake fluid
It better then 170. Only happened since had pads changed so bit miffed no way of proving it though to garage
kfreeth83 is offline Reply With Quote Quote
Old 2 Weeks Ago   #17
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Brake fluid
Quote Originally Posted by kfreeth83 View Post
He wont have touched it tho....
On a pad change itll be not touched at all!
Not even on a drum service
Only thing is
A - generally its failed
B - he pressure bled it and used too much pressure (dowt it)
C - its suffered (saltt)water ingress which has caused it to leak, which in the uk isnt uncommon to rot seals....
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 2 Weeks Ago   #18
Re: Brake fluid
Eurocarparts sell a bosch replacement
Its 150...
But using the current code save30 its 105
Which is still cheaper then fiat
But not as cheap as andrew pages
Ziggy
Meet Bumble-Bee
Old 2 Weeks Ago   #19
Re: Brake fluid
Cheers Ziggy. Spoke to someone they say sounds like opened caliper with fluid cap on
Old 2 Weeks Ago   #20
Re: Brake fluid
Be difficult to take on garage with no proof though. Had car three years before they done pads and never had to touch fluid.
Thanks multipete thanked for this post
Old 2 Weeks Ago   #21
Re: Brake fluid
Load sensing pressure regulating valves are tough . I can't think of any way a pad Change could cause one to leak.
They can leak just through age though.
Another cause of problems is if brake fluid is very old and has absorbed a lot of water. The water in the brake fluid causes the seals to swell. Changing the fluid for new then causes the seals to shrink , leak may ensue.
My thought is problem is coincidental to time of pad Change. These things do happen.
Get it fixed and enjoy your car.
Good luck.
jackwhoo is offline Reply With Quote Quote
Thread Tools
(G) Panda Multijet Diesel Brake Discs and Pads and Brake Fluid Change ytareh Panda 0 24-06-2014 00:39
(T) Brake fluid spraying out when I press brake pedal Firthy Punto (Mk2/2b) 50 10-06-2013 22:26
(T) Brake Fluid Reservoir + Brake Fluid Question oagra Punto (Mk2/2b) 2 21-10-2008 13:13
(T) My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do? keepinitcriss Punto (Mk2/2b) 5 02-04-2007 18:30
stupid question - brake fluid/steering fluid dave FIAT Boo Archives 2 15-09-2003 12:28
