Draedelius
- Aug 21, 2017
- 1
- 1
So I brought a cheap Y reg Punto as my first car, and have had a few minor niggles with the clutch slipping, the rev whilst idling when starting ranging from 600/700 - 1100 rpm(and it fluctuates between these) and an odd vibration whilst idling to name the most prevalent.
But to the big problem, today when I got in the car I engaged the clutch to put it in first and it went farther than normal and it would not return. I can move it myself, but with the engine running the clutch does not engage any more. Also the brakes feel alot more solid.
I suspect, after some research on here, that its one of the cylinders has failed. The dot4 fluid is midway between the min/max lines on the reservoir (could do with a top up but was full 3 months ago if that's any indication).
Can anyone confirm or lend any other suggestions as to these issues?
