- Aug 15, 2013
- 457
- 165
So, as per the threads about the MK2B 1.2 8v engine possibly being the one from the GPs I recently had to do a cam cover gasket replacement due to the bog standard leakiness. Funny thing though is that the gasket I got (from ECP!) is the right one for the MK2 1.2s but not for my MK2B For those of you that have changed a gasket you know that at each end there are two half circle protrusions that the gasket has to go over and the recommendation is to put a little bit of sealant either side of both half circles.
Well......the engine in mine has the two half circles, but one protrudes up and the other is indented down into the head. I called ECP and asked which gasket I needed and they couldn't find one, as I was doing this late on a Saturday I had no choice but to put the old gasket back on but I used a thin bead of sealant all round inside and outside the gasket. Have to say it is (currently) working fine!
Anyone else with a later MK2B with the 8v engine come across this?
Oh, if anyone wants it I've still got the gasket, the packet has been opened but it unused. A tenner shipped an it is yours
Click to see the part, well a nice generic box but it should fit the 'normal' MK2B 1.2 8v engines, the ones the same as the one from this guide:
https://www.fiatforum.com/punto-mk2-2b-guides/340549-1-2-8v-cam-rocker-cover-gasket-change.html
One thing about the engine in mine, there are 6 bolts holding the cam cover on at the top (not 4 from the earlier engines), then 3 hold the coil pack to the cover that also need to be removed on the right hand side.
