FIAT Auto Specialist Team
Thread Tools
Old 1 Week Ago   #31
Re: Let's hope it's the coil packs!
Holes and cracks in manifolds can cause bad running... happened to my first nissan, tiny crack in manifold... ran ok but hit a dip in the road or have a run up a hill from a dip in the road and it would start choking and stay at whatever rpm you was at.
Tried absoloutley everything and then after 6 months, the heatshield on manifold fell off one day when doing a service and there it was... perfect round crack around 3rd hole on manifold pipe bend... bought one from scrap yard and it never did that again.. it didnt even blow from the crack but under tension / flex it opened up and caused hell...
Current car: 06 Fiat Stilo Sporting 150 Multijet
Past cars: 03 Stilo 1.2 Active 16v, 06 Focus 1.4 LS, 98 E36 323is, 97 Astra 1.6, 95 Astra 1.7 TDI, 95 Micra Super S, 96 Almera 1.6 GX, 94 Micra Super S, 97 Vectra 1.6 Envoy, 98 A4 1.8T Sport
dtimmins1985 is offline Reply With Quote Quote
Old 1 Week Ago   #32
wouldnt crack in exhaust or manifold cause engine light to come on ? , im surprised that rough idling hasnt put light on , im getting a code reader tommorow , will code only show if there is a light on dash?
neilcmusic is offline Reply With Quote Quote
Old 1 Week Ago   #33
Not necessarily.
Get Multiecuscan and a lead to connect to your car.
jackwhoo is online now Reply With Quote Quote
Old 1 Week Ago   #34
Just spoke to previous owner , thr punto was sitting for 4 weeks and battery died , he jumped it , I've since read that ECU is lumpy for a while after this , if this is the case roughly how long will it take to learn driving style ?
Old 1 Week Ago   #35
Where is hole in exhaust system?
Have you repaired hole?
Does lumpy tick over after driving?
Old 1 Week Ago   #36
Have you checked air filter?
Changed oil and filter?
Old 1 Week Ago   #37
ECU "learns" quite quickly . It does not learn your driving style it tries to adapt to the engine from the sensor information it receives.
A phonic wheel relearn would be a very good idea.
Old 1 Week Ago   #38
Quote Originally Posted by jackwhoo View Post
Still not replaced exhaust , have bought it but not done it yet , hole is rear of car in middle section am hoping to got this will solve rough idle however I've heard only causes rough idle if in front of cat ?
Old 1 Week Ago   #39
I would have thought the exhaust hole near rear of car is far enough away from O2 sensor number 1 to cause idle problems.
You really should get MES and scan for problems.
Old 1 Week Ago   #40
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Ive jad 3 cracks on my punto manifold
1 on weld feom cat to down stream sensor
No eml
Crack around downstream sensor
No eml
And cant remember where other one was
But except noise i never lost power and car drove fine
If u dont have the gearbox mounted bracket - it can be why it cracks
Since i retrofitted a custom one back on after mine rotted - had no more cracks
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 1 Week Ago   #41
Fault code came back U6100 which appears to be a key coding ref , cleared this , am assuming this is an old code , however no other codes showing , im hoping now that it's just the exhaust
Old 1 Week Ago   #42
Good luck.
Do you just have lumpy idle or does it affect engine when driving too?
The ECU isn't storing a misfire code. so if it is missing the number of misfires in sample period are not exceeding the acceptable number programmed into ECU.
Old 1 Week Ago   #43
Good luck.
Just rough idle , however when it accelerates it make a slight flutterng sound
Old 1 Week Ago   #44
Good luck.
Just uneven idle , however when it accelerates it make a slight flutterng sound , when we were kids we used to put playing cards between our bike wheels and the mudguard and as wheel passed it flickered , it's a similar sound to that , I've just read a similar thread where it turned out to be the ignition coil
Old 1 Week Ago   #45
Maybe the fluttering sound is your mystery pipe ?
If coil insulation breaks down and a spark is jumping from the coil to a ground point, the spark can make snapping noise .
But if this is happening the spark is very unlikely to occur at spark plug and so you would have misfiring.
Thread Tools
(T) coil packs jonyid Punto (Mk2/2b) 4 14-04-2009 12:02
(T) coil packs Bobby Punto Cinquecento / Seicento 12 08-04-2009 23:02
(G) Coil packs lance1 Punto (Mk2/2b) 4 23-01-2007 22:30
(T) coil packs PNL Stilo 21 10-02-2006 00:39
(T) coil packs mottles Stilo 9 30-11-2005 13:43
