UncleJambo83
- Feb 8, 2017
- 10
- 2
setting out for a drive yesterday the clutch pedal went all the way to the floor and didn't come back up. Luckily I hadn't got too far from the house and I was able to get it into first, with the ignition off, restart it and carefully drive it home... snails pace.
Anyhow, hoping to diagnose the fault and determine whether it's a DIY job or not. Currently, with the clutch fully depressed, it doesn't disengage the clutch from the gears. I've read elsewhere that it could be a fluid leak and have fresh, clear oil on my drive consistent with this. However, I also read that the clutch and brake system share the same fluid reservoir.. but mine currently appears to be at the max level.
1.2 sporting
Cheers in advance
1.2 sporting
Cheers in advance
