If you have a key but it's a bit worn.go on to carkeyhelp send a good photo and he can cut you a new one.mine cost£13 with post and it came next day,if you know the code number you can get a new transponder chip as well for not much more
Most people dont have there ID cards as 99.9% were binned from import
That 0.1% that have them probably have paid for a replacement OR had a new barrell set so the dealer left them with the card
So add £15 - 20 if you aint got your card
I just paid £60, somebody came to me - hooked up his stuff, got me a new key Cut to compensate wear and programmed for 60
Done in a short space of time too
No worries about key been potentially wrong
Ziggy
U couldI have the two original remote keys and the original non-remote spare key plus the Fiat mechanical and electronic code card.
One remote key is badly worn and it would be nice to have an el cheapo replacement but I am in no hurry.
U could
If the blade worn not the button or transponder
Buy a blank key case
Swap electrical gubbins over once key blade has been cut and compensation for wear has been added
Probably done for under £25
Ziggy
