As above oil is light red/brown which is gearbox oil is leaking at end of transmission. It looks like a sealant is gone but I am afraid if I remove the cover mind have spring pop out and etc. then I can't put it back. Will it be ok for me do at home or need a specialist to do the job? What about a leaking sealant mixed with oil to prevent do big job is really work or not?
i had an old 8v tranny leaking out of the side pan which is what you are totally describing to me
Now the gearbox's are different, but i dowt owt major will be attached to the pan when you take it off...
Mine didnt anyway
You will need to first of all free off the Fill plug hole BEFORE DRAINING TRANNY
why? when you drain it and THEN find out you cant fill it... oh dear indeed....
So once you know you can fill and then drain
Simple let it drain for about 300000million years as it slowly keeps dripping
Clean both surfaces up of old oil / gasket / contaminants (brake clean is nice here when sprayed onto a cloth)
Once all clean - fresh sealant suitable for oil pans / transmission pans and let it go off
Then refill and check for leaks
mine turned out to leak down the threads... gearbox rebuilder had split the gearbox a small amount so my leak never stopped, but it was a teaspoon every week or so... so no biggie
Ziggy
