Z zoutpansberg New member Joined Apr 13, 2017 Messages 6 Points 2 Location Louis Trichardt South Afr Apr 15, 2017 #1 My Punto steering went hard, I repaced both the steering moter ,ecu and battery, no luck . Checked all fuses and relays .Charging good :yuck: Any member with advice pse
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,994 Points 7,838 Location Near the M4 Apr 15, 2017 #2 Hi, and welcome to FF, odd scenario.. maybe the column itself has an issue.. somehow this is in the UNO section..?? Charlie
OP OP Z zoutpansberg New member Joined Apr 13, 2017 Messages 6 Points 2 Location Louis Trichardt South Afr Apr 15, 2017 #3 Thank you noted Uno section will check next time Last edited: Apr 15, 2017
