Technical Punto 1.2 8v 2 cylinders after ECU, Coils, HT and sparkplugs changed
MK2lover
My mothers 2001 8v 1.2 Fiat Punto is running on 2 cylinders.
I've changed spark plugs, coils, HT leads and the ECU (self programmable from eBay), but the problem still remains.
It has thrown unrelated error codes: P0115 and P0120.
Does anyone have any idea about what could be wrong? Is the most likely thing a bad connection?
running on 2 cylinders is almost always bad engine ecu
did errors came back after you cleared them?
No, the error codes didn't reappear after I erased them.
But as mentioned I just fitted a new ECU and the problem is exactly the same. I wonder what else could be wrong?
I had the exact same problem [front coil was suspect], sometimes she was on 4 sometimes on 2.
I took the air cleaner off, put a separate earth from the ECU body across to the negative terminal on the battery, no bloody difference!
I started to fiddle about with the feed wires from the top of the coils that disappear into the loom, for some reason she ran on four & the more I fiddled I could actually make her run on 2 or 4. Buy, steal or borrow a tin of 'contact cleaner' spray brake cleaner will do, & give the tiny connections on both coil feed plugs a good dowse & hopefully that may do it.
Or........send the ECU back saying it doesn't work. I had one from 'amscarsp' & was very pleased.
Hope the above helps.
The timing belt had skipped 1 "gear tooth". It has now been fixed, but the engine is still running very badly. It constantly runs bad, but I'm unsure whether or not it actually fires on all cylinders.
I tried to reset the ECU by repping 5k 2 sec, stopping, repping 5k again etc. The result was a big blow/bang coming from the engine. I stopped and the engine continued to run unevenly.
Ziggy122 does this still sound like the ECT?
Why did the belt jump? Gone slack? Auto adjuster sloppy?
A ect thats stuck at negative 40 for example will be seriously rich
The more fuel means more chance of it dropping into the hot exhaust and causing a "backfire" hate that word...
Anyway - see why the car is missing
Its gonna be mechanical or electrical
Id blame the ecu last.... as there harder to diagnose correctly
Live data read outs are good way to see what car see's
Ziggy
Ziggy
Don't know why it jumped. It was nice and tight. Might have been installed that why by a mechanic when the belt was changed 2 months ago.
Will measure the ECT's resistance...
Here is the full ODB readings when idling (Outside temp 4 C):
Not sure what most of these should be for a Punto, but ECT sensor seems fine?
Compression test showed no compression on 2 cylinders. Turned out to be a broken head gasket. Head gasket had been changed 2 months ago. Now running perfect again (y)
Hi Guys,
I have a similar (and all too common?) problem:(. She runs on 1 & 4 only. I have tried changing the ht leads and coil pack. Checked the low voltage connections to the packs (my voltmeter shows 6 volts?). I am reluctant to condemn the cylinder head just yet. I have the OBD Auto Doctor software on my computer and wondered if getting the multi pin connector for the car would pinpoint the fault :confused: Anyone tried that route?
Cheers :)
Hi Guys,
Cheers :)
spark plugs or engine ecu
errors?
Only way to really tell if HG is causing an issue is a compression test.
One of my previous cars (Which wasn't a Fiat) had an HG issue, oil and water were clear, BUT the Engine started eating thru coolant at a rather impressive rate....which ultimately cost a lot to fix.
