Technical no starting
aFiFi
alexandria
hello everyone ,
my mk2 1.2 8v gave me a new challenge yesterday ,
i can't get an ignition
the ecu loads good and then when i try to ignite it looks like an electrical circuit error occurs , all the gauges cursors falls down and then the car reloads again .
i want you to notice that i have a fixed broken battery chassis it might be the reason ,
i recharged the battery just to make sure but no luck .
please help me my fellow punto geeks ,
much appreciated
best regards
:slayer:
take the cover off the fuse box next to battery
see if the power lead bolted in there is a lump of rust
if it is take fuse box out and remove the fixing and replace with a new bolt
you might be amazed this might be your issue
