tonyforristal
- Mar 23, 2017
- 8
- 1
I'm having a similar problem with my 2002 punto, posted about it in another thread but as it seems to be very similar thought I might chip in here.
When accelerated to approx 3000rpm (usually between 2700 and 3100) I lose power for a half second, the EML flashes on and then the power comes back and the light goes off. This happens every time I rev to 3000.
Ran the ECU scan, no faults reported.
IN the parameters section, I got the following readings:
Lambda 1 Precat status: Closed Loop
Lambda 1 After cat status: Open loop (this should be closed I think?)
Lambda 1 Pre cat signal: Approx 0.7V at idle and at 2000rpm
Lambda 1 After cat signal: Approx 0.7V at idle and at 2000rpm.
Lambda 1 Precat and after cat diagnosis flick between rich and lean at idle and at 2000rpm.
Lambda 1 check pre cat: OK
Fuel system monitoring: OK
Cat Converter monitoring: OK
Tried to run the Self adaptation reset and phonic wheel reset, says conditions not suitable for both (despite engine being hot).
If anyone has an idea of what this problem could be I'd be very grateful!
