MannedSage1
- Dec 21, 2015
- 68
- 25
Can someone tell me the differences between the 1.2 8v and the 16v I know the engine is different but what else is
Alot really...Can someone tell me the differences between the 1.2 8v and the 16v I know the engine is different but what else is
Thank you what about interior and dialsAlot really...
16v has 8 inlet valves and 8v exhaust
Vs 8v which has 4inlet/4exhaust
More valves = more power
8v is 60bhp
16 is 80bhp / 90bhp in modern versions
Different exhaust manifold, inlet
Blocks are slightly different
Heads completly different
8v is a safe engine = if belt breaks the valves wont smash on the pistons
Yet 16v isnt safe its an interferance engine, the valves will hit pistons and will cause damage
Luckily they bolt gearboxss together
Both can use the 5 and 6 speeds
But flywheels are clutches are slightly larger on the 16v iirc, believe they can be interchanged tho...
8v are very common lumps, 16v are common... if u get a sporting etc
Ziggy
Front discs are smaller on the 8V iirc.
Same Size IIRC but sporting has vented discs
The 1.4 had slightly bigger discs IIRC
8v' has a thick single slider pin
16v has twin slider pin calipers
I've cooked a 8v's disc's before, but tbh, i was racing around, and it did have a sticking caliper issue (duff slider) causing the overheat
Ziggy
Euro list 3 discs for a 2003 1.2
240mm solid
257mm solid
257mm vented
What runs 257mm solid i wonder?
I might keeo eye out for 16v setup as towing can cook brakes for me...
Only on the 240mm solids
Ziggy
Ziggy
