if you cant find it there; look at the timing belt cover (on the left, drivers side), follow it down to the bottom and the number will be on a flat edge on the engine block just above the coolant pipe feeding the water pump.
easier than it sounds
hope this helps
sexy black 3 door punto with wild yellow interior.
