Technical 1.2 elx 8v no speedo, no abs light, abs kicking in...
Trodai
Iv a mk2 elx punto 8v I just bought it, iv fix airbag issues and all that is left is this problem/problems
Iv put it on diagnostics and only fault in system is no communication to airbag light,
The speedo reads 16mph but then stops... the 4 speed sensors read up to 16mph then it appears the abs module shuts down as I lose connection with the abs module
Iv used 2 different diagnostic systems and this happens on both anyone come across this before?
Car definitely has Abs, I'm thinking the a replacement ecu has been fitted is there a coding difference between abs and non abs models, I imagine there should be?
Don't have a picture yet... it definitely has abs... is there different ecu for abs models or is it just coding... garagethan previously changed ecu can't remember if it came off a abit model and can't tell me if the speedo was working then either...
