Morning,
Firstly, not really a FIAT expert, I usually work on VW's so be gentle
Friend of mine has a 1.2 with overheating issues. Within 2 minutes of sitting idle, the vehicle is overheating and the only way to keep it running is to drive fast with the heater blowers on full.
I've had a look and there's potentially an issue with coolant being lost. I don't know if it's a leak but apparently it lost from the max level to just below, however it's overheated a few times and I just wondered if that coolant has escaped under pressure maybe?
He's also said the electric fan by the radiator isn't cutting in. I've not tested this (we're going do some more at lunch) but I've had the relay box off and relay T10 is missing (or at least the slot is empty). Is there anyone who knows what this relay does?
Any other places to look out other than the obvious (oil etc)?
