Technical Track rod end stuck on track rod
As part of my annual MOT ordeal (lol) I am doing an O/S track rod end. It was easy enough to get the retainer nut loose; bit of heat, couple of soakings in good old wd40. But bugger me if the track rod end isn't seized hard on the inner tie rod!
Anybody had this happen? My main problem is I can't get any strength into it. Have got a set of plumber's grips (footprints) on the tie rod end near the ball joint, but finding it really hard to get any purchase on the tie rod. I've got some pump grips on it but it just keeps spinning round....
Any suggestions please? I'm off back outside in the cold with my blowtorch hahaha :cry:
Aye track rod ends can be a pain with rust. Simple job turning into pain in the bum. Failing a good soaking & some heat, you need to get the big guns out in the form of a gas axe, get the area red hot, that will sort things out.
Just for the record, if the inner rod threads are badly corroded, it's likely you'll have to replace as well. a wee tip is to clart the new threads with anti wash off grease, even covering with amalgam tape will help the dreaded rust.
Having another look at your pic' & I don't want to sound rude, but you could be using better tools that are up to the job..Just my thoughts.
Get two decent hammers, preferably lump hammers and hit them both against the track rod end on opposite sides at the same time, Also a bit of heat would help, You need to hold the threaded end from the rack steady so put you decent wrench on that end, if the stilson has decent sharp jaws use that, the ball joint is easy to hold as you have the joint itself to hold. If you have backed of the lock nut a couple of turns, try tightening the end first before you try to loosen, Sometimes it's easier to do that.
Not at all! The essence of my question is; what tool SHOULD I be using instead of the red handled pump grips in the picture. Obviously I am a novice mechanic with limited tools. But my stepdad has a fairly well stocked garage, and I'm willing to buy tools off ebay/amazon...
If you were doing this, what would you be using?!
The problem is, the inner tie rod is essentially a long thread with no flat edges to get a shifting spanner or plumber's wrench onto?
Locking pliers/mole grips? Some other kind of vice grip?
Appreciate your answer, good tip re the grease and tape idea (y)
Thanks for the tips! Will try that with the two hammers. :)
Had this on mine
Some bastard haf used thread lock, after several adjustments and not been cleaned, it was like rubber balld which jammed it up
I was forced to cut with a 1mm disc a slot in the track rod, just deep enough to release the threads to allow them to turn
I copper greased them back on up plenty on refit so that it shouldnt stick again
Ziggy
You can buy a lock nut that slips over threads for this kind of application. Can't remember where I saw them last. Alternatively, one of those self tightening spanners (gets tighter the more torque you out on it) might help.
It'll only be the first few turns of thread that are rusted solid
Loose should be sufficient. Being visible should be no problem.
But you could be right he was talking about the ball joint nut.
I was talking about the nut highlighted in the photo above, it only needs 1/2 turn but I gave it a couple to get it out the way of the blowtorch and give more space for the wd40 to find its way in...
Got myself a set of mole grips! Angus vs the TRE round II today after the footie :)
