well convinced the Mrs to get a fiat as well as most know im fairly handy with a set of spanners and know my way round a Grande..
so was supprised when she wanted to go view a mk2 she saw on Facestalk local selling page...
anyways to cut a long story short guy buys car for son for christmas spends thick end of £300 on it £170 in repairs plus new exhaust (cat back) and 4 budget tyres, saw the invoices.. know the mechanic that did the work personally (old drinking buddy ) so he confirmed the car was half decent
took another mechanic mate to view second time round drove it away for £400 (was up at £480)
nb say drove it away got another mate to put it on his recovery truck and drop it on our drive as currently sorn and not insured £20 well spent to avoid any legal issues ....
so i begin full service (had cambelt 40k ago so ignoring that for now)
Oil filter had seen better days..
trying to get the air box off proved more hassle as the steel bolt had cold welded to the coil pack bracket (aluminium) so had to make a new bracket..
then use a broken screw remover on all 14ish very rusty self tapping air box screws :bang:
spark plugs had paid for themselves
whole car washed and steam cleaned top to bottom all loose underseal removed wire brushed and any bad rust treated with bilt hamber hydrate left to dry then got busy with the old but cheap waxoil cavity wax and waxoil under body with a schultz gun / cavity lance on the compressor
found one bit of perforation near the N/s workshop jack point where some muppet had jacked it up wrong a while back leaving a delve in the rear foot well and a hole has formed with rust :bang:
so insides stripped and hammered back flat
patch made ready to be welded....
flashed over with weld through paint to keep it clean till i get my hands on a welder...
at this point she needed a good clean
clay mitt and glaze later
also found the servo vac hose had worn through due to the inlet manifold loom rubbing on it £1 local scrap yard fixed that
just need some rear break shoes as they are almost down to the metal £20 ish
NOW for some questions
any special precautions prior to welding bar removing the battery negative?
and how the hell do i get the rest of the air out the heater matrix after changing the coolant? run it in cycles of revs with the stat open and fan running squeezed the hoses and opened and been scalled by the coolent coming from the bleed points?
