any thoughts would be appreciated....
Noticed yesterday and today that my Temperature Gauge was running 1/2 way between quarter mark and halfway occasionally (mainly with heater on), previously it has always gone to halfway and stayed there even with the heater on at full blat. Also carpet on Drivers side is soaking wet, although the area around the centre console is dry as a bone.
I've had a good look round the door and windscreen and underneath the dashboard but can find no trace of any leak anywhere. I'm wondering if the car has maybe developed a leak in the heater matrix ? yet I have checked coolant level and it is where it should be, and the heater is still blowing hot air.
I removed cap from the expansion tank and expected a hiss from depressurization, sounded quite quiet to me as if it didn't have a lot of pressure although there was a hiss, checked around all the rad hoses including heater ones for signs of leaks and with pressure cap off the expansion tank gave all the hoses a good squeeze in case there was any air in the system, all hoses were hot so obviously coolant is circulating through them.
After i had done this the gauge seemed to have settled back to where it should be even with heater at full blast.
Not used to see a Temp gauge drop, normally if there is an issue temp goes up in my experience.
Apart from this engine is running fine, no other issues at all with it.
