sparkymk2b New member Joined Oct 27, 2012 Messages 87 Points 33 Location Italy Aug 24, 2015 #1 Hello. I have small question. I wanna use plastidip on center console and before I do this I wanna know how to remowe this sticker from backside. Is it stick with glue or just screwed?
D deagz New member Parked in the garage Joined Jan 11, 2015 Messages 115 Points 32 Aug 25, 2015 #2 I think they might be heat sealed on but a dremmel or small cutting tool will do the trick and just glue them back on
AndyRKett Distinguished member Parked in the garage Joined May 23, 2011 Messages 14,245 Points 3,358 Location Norfolk UK Aug 25, 2015 #3 It's held in place by melted plastic, it's also very fragile and likely to break if you try and remove it
D deagz New member Parked in the garage Joined Jan 11, 2015 Messages 115 Points 32 Aug 25, 2015 #4 i've found using a soldering iron usually works quite well, just don't breathe in
