Hi guys,
I hope you can help with an issue I'm having, I had the MOT completed on my 03 plate MK2 Punto today, and it failed , on a number of things, but one was a detective registration plate light.
I picked one up from Halfords to replace the bulb and came across my problem, there wasn't one there in the first place, the plate is damaged and when the bulb was replaced it did not work.
I bought the car about a year ago and the dealer had an MOT carried out at the time which it passed. Having removed the light plate/lenses there was no bulb, so don't know how it passed MOT a year ago.
The plate/lenses is damaged, the collar where the bulb fits is snapped off from the horizontal plate that holds the lenses and the socket for the bulb is also heavily corroded.
When I replaced the bulb and put my lights on the bulb did not light, as far as I can see the light is on the same fuse circuit as the instrument panel which works fine.
So my question is can anyone think of anything else to check?, As the light isn't working but other things are, I'm assuming it's the corroded socket or bad wiring, both of which probably aren't know by the garage, so the cost would rocket if I got them to sort the issue.
