- Jul 1, 2015
- 97
- 28
In the short time she has had the car, Chloe has said every time she pulls away or draws to a stop she can here a noise as if there is water trapped somewhere in the firewall area or door bottoms swishing around. The area beneath the windscreen wipers is clean and the drains are also clear of dirt and debris. There is no water accumulating in the door bottoms (3 door 1.2 8v 2001) as the drain holes are clear. We are worried there may be a connection with the clutch and this indicates an imminent problem. On the subject of clutch I cannot find a fluid reservoir other than the brake fluid reservoir. Are the two systems sharing the same fluid? I know the brake fluid was originally at the low level because the warning light would come on with the car's movement. In the course of maintenance I flushed the brake fluid with new DOT 4 using a pressure bleeder and the level is now fine. How does one bleed the clutch circuit?
