- Mar 2, 2015
- 541
- 160
Yesterday I was on a cross country trip in my 2005 1.2 8v, and on the way home it suddenly lost the torque. At the time I had been cruising behind a truck on the motorway for a good hour, at around 2400rpm. Suddenly the engine just dipped to 2200rpm and there was no torque at all. Engine light came on. I pulled into the next rest stop, switched off the engine and straight back on. Pulled out of the rest stop at full throttle and there was no issues at all - except for the engine light remaining on. Caught up with the truck again, and settled into the 2400rpm range again. Every now and then the engine would be hesitant and lose torque, but only for a second or two.
After having had those hesitations, I decided to give it a bit more throttle the last bit home, and accelerated to 3400-4000rpm. It was again hesitant for a second or two just as I reached 3000rpm, but then felt nothing for the last 25-30km home at higher speeds.
The error read out was a fault on coil pack 2, but to me it didn't seem to misfire at any point - so I'm thinking it might be a sensor?
