More often than not when I turn a corner in my 55 plate mk2b the handbrake light comes on. Then when I'm going straight again it will turn off. Is this a sensor issue?
Brake fluid is low. Pretty typical trait of mk2 puntos.
When you top it up be sure to take the small filter out of the top of the reservoir as it prevents the fluid getting into the bottle and then makes it look like its full when it isn't
