Technical Window regulator for Mk2b 5 door
gingel
Israel
Hello,
Anyone knows if the electric window regualtor for the Mk2 99-03 also
will fit in a Mk2b 2006 ?
It's for the 5 door model.
Is it the same part? Or the Mk2b is different?
Thank you.
Are you sure there is a difference between the 5 door and 3 door ?
I found this on ebay, and it says it's for 3 door and 5 door:
http://www.ebay.co.uk/itm/Fiat-Punt...103?pt=LH_DefaultDomain_3&hash=item2a49a35037
Can someone identify it by the picture?
Also, i saw there are regulators with metal cover on the gear, and
some have plastic cover.
(For example, the link above is with the metal cover).
Here is a link for a regulator that have plastic cover:
http://www.ebay.co.uk/itm/PUNTO-MK2...Domain_3&fits=Model:Punto&hash=item1e9d74e750
The regulators with the plastic cover came with the newer models?
Thank you.
Thank you.
Maybe anyone else knows?
I found this thread on how to remove the door card, looks not too hard.
Is it difficult to remove the regulator after the door card is off?
it may appear 3 and 5 door regulator is same
95 squid!
http://www.ricambio.co.uk/816-o-s-front-window-winder-regulator-motor--fiat-punto-mk2
Price: £79.95
Inc. VAT: £95.94
Electric Window Winder Mechanism and Motor to wind the Front window up and down
O/S Right Hand Door
Fiat Part No: 51764549
RRP: £211.50
to fit:
Fiat Punto MK2 all models 3 & 5 Door (from 1999 to 2006)
(If you chassis number begins with ZFA188... then this is the correct part for your car)
Do you think it's a good idea to install a used regulator?
The used regulators i saw on ebay are from cars, that are from 2001,2002.
Thank you, i'll order a used regulator.
How hard is it to remove the regulator after the door card is off?
Can't find a guide for that.
Thanks.
first you need to remove window by uncliping this plastic thing in pic, then just remove bolts and fit new regulator
If the same as the mk 2 then its just bolts (Looks the same), ive just removed two from my scrap doors
Thanks :) good to know.
Do you have enough room to take it out, or is it PITA to remove it?
so i ordered and received a window regulator, but the regualtor
they sent have a few problem.
First, one of the bolts that hold it to the door is missing.
Can i install a bolt from the regulator that is now inside the door?
Is this bolt is riveted, because from the other bolt i can see it's pretty solid
in place.
A few plastics are broken. are they important?
Thanks.
