Hi guys!
I have a very strange problem with my mk2 1.9 jtd. I have searched the forum and found nothing like this:
Sometimes my punto stalls, it just dies on me when I try to make rapid accelerations. When I put the gas pedal all the way down at about 2000rpm, I have full acceleration power, car speeds up fine, but sometimes if I keep pushing it too much, it dies. I have to pull over, turn off the key, wait for 10 seconds, and it starts again just fine.
There is no error or warning lights, it just goes down, and then it starts normally.
Let me give you some info: The original 80HP motor was damaged, and I recently bought a new (used) motor. Seller told me it is a 115HP one. No repro was made to the ECU, so it still is factory default. Car is running fine, I have made many km with it now with no problems. It speeds fine, even at high revs and with no power loss even uphill.
Only problem is just when I try to speed it too fast, when I push gas down fast, I feel some vibration when the turbo kicks in, car speed just shoots like hell, sometimes front wheels drift on the road even in 3rd gear , and if I keep pushing it, it stalls and I have to stop.
Any ideas? I'm thinking it has something to do with de turbo pressure, because everything else is fine if I dont push it.
Any help would be appreciated.
Thanks!
Thanks!
