On heavy braking - good chance the abs will activate
Why?
its sensing a near wheel lock situation on 1 or more wheels
So the ABS overides to ensure the wheel doesn't actually lock up
It goes through 3 phases after the original brake pedal application
So the ABS unit detects a wheel is rapidly slowing down - ie its about to lock
It enters its 1st phase
- Pressure maintain
the 1st phase locks any extra pressure been applied by the driver to the offending wheel to prevent total lock up
2nd phase
- Pressure release
Car detects that wheel is again still rapidly slowing down, almost about to lock up, the release valve is opened removing the pressure from the offending brake, allowing wheel to speed up again, this fluid is then pumped back around via a buffer for reuse
3rd phase
- pressure increase
The car now see's the wheel is spinning at a similar speed to the others, but you are still requesting anchors to the max
The car allows pressure to be built back to the offending wheel to reapply the braking force
This 3 phases will constatnly keep repeating if 1 wheel is about to lock
Ziggy
