Starting to think it's likely to be a half-open thermostat. The temperature gauge took longer than usual to move up from C. Is it a complicated job to replace the thermostat?
It is an easy job if you have 3 or even 4 hours to spare and are prepared to spend at least an hour cleaning up the place on the engine where the thermostat fits. Everybody is using a silicone sealant for the new thermostat but i used the supplied thin paper gasket along with the silicone - others are not using this gasket. I got no leaks. Some people do this job and get leaks. Cleaning the engine seems to be the biggest part of being successful.
You will need to get the bottom hose undone from the radiator which needs to be done with care to avoid breaking the plastic radiator. The hoses tend to get stuck on and have to be removed slowly rather than with brute force. The hose on the thermostat also has to come off but that is metal and you can be more forceful. Getting the hoses off requires time and persistance rather than brute force. Twist and hold one direction and twist and hold the other direction and that sort of thing
The job is more or less impossible unless you remove the coils above the thermostat so you can get your hands in there for cleaning the engine - that is an easy job however but I found it easiest to pull the plugs off the spark plugs rather than get the spark plug leads off the coil - you need to move the coils out of your way without stressing the spark plug leads which do not like being pulled upon.
You will need to refill with antifreeze even in the tropics to prevent corrosion and before you refill you should flush thru the system as best you can by putting the water hose inside the hoses from various directions till you have sufficiently clean water.
Most of the forum seem to be stressing getting air out of the system once you refill with coolant, but
providing you open the radiator bleed screw the rear one is not important, but you must keep an eye on the reservoir level till the engine is hot and make sure the reservoir is near the max level before you go off for a test drive
and keep an eye on it for a few days. If you break off the air bleed screws that is another job you will have to spend time fixing, particularly in a hot climate where the cooling system is stressed to the max - and they are easily broken.
So it is not a totally easy job which is why i was wanting you to be sure the fan was working properly. Too many people today just seem to change this and change that to fix things rather than being systematic about it. Maybe changing this and changing that is a faster way to get it fixed though. Diagnosing can be more of a lifestyle or hobby!
Once you have the old thermostat out there is no harm in putting old and new in the same saucepan and bringing them to the boil to check the new one opens later than the other. If they are the same then the old thermostat was ok or you have the wrong new thermostat
