Oooo i just thought they'd fit may have to ask my scrappy and measure a couple up and see what I find I imagine their 60 degree taper just unsure about other measurements
the bolt circle and central hubs will fit fine no problem
I'd ask for the bolts from the scrap yard - as im sure they are same threads as the mk2
it'll go in easy if so - if not and it stops quick - its not right....
M12x1.25 is correct, from what I recall taking the wheels off the GT 60 degree taper sounds right. The only other thing you'll need to know is the bolt length.
That sounds far too long to me, I'd think more like around 32mm. I was going to fit some aftermarket wheel to my Seicento and with 10mm spacers I need 40mm bolts, so I doubt 53mm unless you're fitting massive spacers too
