guybusc New member Joined Aug 21, 2014 Messages 77 Points 34 Dec 22, 2014 #1 Hi Guys, I wanna upgrade my door speakers but just unsure on what measurement they are. Anyone known? Thanks Guy
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 22, 2014 #3 guybusc said: * it's a Mk2b Click to expand... IIRC there 16.5cm But i cant remeber to be honest You will also need an adaptor for standard wiring to aftermarket http://www.ebay.co.uk/itm/CT55-FT01...2?pt=UK_In_Car_Technology&hash=item2a37878034 Ziggy This post contains affiliate links which may earn a commission at no additional cost to you.
OP OP guybusc New member Joined Aug 21, 2014 Messages 77 Points 34 Dec 22, 2014 #4 Thanks, the link won't load it just leads me to the eBay homepage
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 22, 2014 #5 guybusc said: Thanks, the link won't load it just leads me to the eBay homepage Click to expand... item code 181320253492 It works fine me the link? Ziggy
AndyRKett Distinguished member Parked in the garage Joined May 23, 2011 Messages 14,241 Points 3,356 Location Norfolk UK Dec 22, 2014 #6 For some reason if you're using the fiat forum app, all eBay links go to the eBay homepage. They will work normally thought the website though
OP OP guybusc New member Joined Aug 21, 2014 Messages 77 Points 34 Dec 22, 2014 #7 Ah yes, thanks mate.
OP OP guybusc New member Joined Aug 21, 2014 Messages 77 Points 34 Dec 22, 2014 #8 Ziggy122 said: IIRC there 16.5cm But i cant remeber to be honest You will also need an adaptor for standard wiring to aftermarket http://www.ebay.co.uk/itm/CT55-FT01...2?pt=UK_In_Car_Technology&hash=item2a37878034 Ziggy Click to expand... Sorry im a bit of a beginner with all this stuff but what does the adapter actually do? And for example if i bought these http://www.ebay.co.uk/itm/PIONEER-T...8?pt=UK_In_Car_Technology&hash=item3cc5397138 would it be a straight swap? This post contains affiliate links which may earn a commission at no additional cost to you.
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 23, 2014 #9 guybusc said: Sorry im a bit of a beginner with all this stuff but what does the adapter actually do? And for example if i bought these http://www.ebay.co.uk/itm/PIONEER-T...8?pt=UK_In_Car_Technology&hash=item3cc5397138 would it be a straight swap? Click to expand... Yes if you use the adaptors No adaptors you will need to cut the cars fiat connectors off and crimp/solder new terminals on The adaptora are plug and plug and play Ziggy This post contains affiliate links which may earn a commission at no additional cost to you.
