You might be best to invest in some kkl leads & Multi-ecuscan.
MAP SENSOR DRIVABILITY SYMPTOMS
Anything that interferes with the MAP sensor's ability to monitor the pressure differential may upset the fuel mixture and ignition timing. This includes a problem with the MAP sensor itself, grounds or opens in the sensor wiring circuit, and/or vacuum leaks in the intake manifold (airflow sensor systems) or hose that connects the sensor to the engine.
Typical driveability symptoms that may be MAP related include:
* Surging.
* Rough idle.
* A rich fuel condition, which may cause spark plug fouling.
* Detonation due to too much spark advance and a lean fuel ratio.
* Loss of power and/or fuel economy due to retarded timing and an excessively rich fuel ratio.
A vacuum leak will reduce intake vacuum and cause the MAP sensor to indicate a higher than normal load on the engine. The computer will try to compensate by richening the fuel mixture and retarding timing -- which hurts fuel economy, performance and emissions.
MAP SENSOR CHECKS
First, make sure engine manifold vacuum is within specifications at idle. If vacuum is unusually low due to a vacuum leak, retarded ignition timing, an exhaust restriction (clogged converter), or an EGR leak (EGR valve not closing at idle).
A low intake vacuum reading or excessive backpressure in the exhaust system can trick the MAP sensor into indicating there is a load on the engine. This may result in a rich fuel condition.
A restriction in the air intake (such as a plugged air filter), on the other hand, may produce higher than normal vacuum readings. This would result in a load low indication from the MAP sensor and possibly a lean fuel condition.
A good MAP sensor should read barometric air pressure when the key is turned on before the engine starts. This value can be read on a scan tool and should be compared to the actual barometric pressure reading to see if they match. Your local weather channel or website should be able to tell you the current barometric pressure reading.
Check the sensor's vacuum hose for kinks or leaks. Then use a hand-held vacuum pump to check the sensor itself for leaks. The sensor should hold vacuum. Any leakage calls for replacement.
An outright failure of the MAP sensor, loss of the sensor signal due to a wiring problem, or a sensor signal that is outside the normal voltage or frequency range will usually set a diagnostic trouble code (DTC) and turn on the Check Engine light.
