Hi
my car has a slight judder at idle (used to be worse but something ive done has helped) i can feel it juddering only on idle, car runs fine when on the move.
so far ive replaced ht leads, replaced alternator belt, cleaned throttle body, checked cleaned and re-gapped plugs, bled coolant system, checked throttle cable, idle valve and hoses going to throttle body.
the idle stays at 900rpm when up to temperature but can still feel it and when cold you can still feel it but it shows the idle pulsing from 1100rpm to just under 1200rpm
all help would be appriciated, Alex
