UnclaimedSock
- Oct 29, 2012
- 149
- 40
Hi all, Iv just bought a mk2 1.2 8v pretty cheap with a suspected head gasket failure... Just wondering if anyone can confirm for me.
The symptoms are:
Slight miss fire from cold (presumed water in the cylinders)
Temp guage going 3/4 up the gauge
Pressure building in the pipes so the rad cap has to release the pressure out
When I undo the rad cap a little the coolant comes out under high pressure
White smoke from the exhaust
I believe the head gasket to be gone from one of the coolant journals to the cylinders
The previous owner had it pressure tested and told me that it has a very slight pressure leak
Any help would be greatly appreciated, cheers
The symptoms are:
