- Apr 8, 2008
- 16,742
- 3,186
Well its happening again
Bumblee-bee got a new gearbox very shortly after me having him - i got him with 60k on the clock, and i've just passed 76K
When i say new - it was a reconditioned gearbox, at same time i slammed a new clutch kit (LUK) in as i had a noisey box and clutch judder
Some 15k later, i've become somewhat very un-nerved by the imminent sound of another ka-ching and a new gearbox step again
So whats my problems is simply noise
A rumbling noise when clutch engaged in neutral
dipping the clutch the noise will dis-appear
But when driving in 1st, 2nd and 3rd, i get a sorta ratchety bearing noise when on the power which is mid volume 4th and 5th is somewhat to quiet to judge
If i balance the power input i can get it alittle bit quieter
Come off the power and you then suddenly hit with the noise, alot louder
If you are stepping from 3rd to 1st when nearly stopped, you get a very disturbing "whine" as the gearbox is sped back up as i stop
I've had 1 mechanic listen to it with me and he's pretty sure that its the sound of the differential bearings failing
So what do i know?
Its got plenty of fluid - always has 75w-90
Its NOT the input bearing been playful, i've had the box out and checked it, it spins a tiny bit more freely then the new one that was sat on my desk. It certainly didnt ""play""
Gearbox tho did look in nice condition inside though, nice shiny pointy gears, nice syncro's too
So i'd say it has been rebuilt, but failing bearing wise, which tbh is punto boxes all over
So what do i do? i'd like to hear your opinions
A - Get ANOTHER recon box, @ 265 smackers from ebay
B - Get a salvage box that from a 16v 5speed punto unknown conditio, take it apart as best as i can to check it over, wack a new input bearing in since it never got fitted to my current box, and prey its okay
C - Wait til it goes bang = scrapping the box, which is a shame as the gears are sweet as a nut....
D - Get this box reconditioned?
You may remember me with my mk2, having a total of 5 boxes in there (1 been the original one i had in it) (yes i had 4x gearboxs in the 3years i owned it)
Im not going to get rid of the car, i love it to much
Instead of been stingy its time to spend some cash on him to get him better me thinks
Where would you go? what would you do?
Ziggy
So what do i know?
Ziggy
