Technical Engine control unit
Tommyk
Hylke Denmark
Hi Forum
On My punto 1,2 16v year 02 is the engine ecu not working the right way, number 0261207901 if I found a used box with the same number does this work on my car or should I buy one new and then programing it on my car. The car is misfiring on cyl. nr. 3. Sparkplug and other´s in ignition is ok.
Tommy B.Korsbakke
Iirc the coil pack is .ore likely to be cause
As it runs 2 sparks at same time like the 8v
It has a common ground and 1 of the other 2 pins spark 2 cylinders
If 3 isnt sparking then no2 wont be either
Getting another ecu wont work as youll need the locks and keys and dash and fusebox from another same spec 16v punto
Ziggy
Ziggy
Hi Ziggy and others.
I have tried out resistance in spark plugs cable =ok. Coil is brand new. Sparkplug =new. The 2 lamdasonde on the catalysator I have changed for a month ago.
Fuel injector, I have reversed with number 2 cyl. Still number 3 misfiring. When I take off the wiring connector to injector nr.3 you cant hear any change off the engine, but when I do this with 1,2 and cyl.nr.4 you can hear it on the engine. Then someone told me it is the ecu box. Fault codes with ecu scan is P0420-P0300-P0301-P0303.
When I take off connector on cyl. nr. 3 Fault code is P0203.
Kind Regards Tommy.
Hi All
Now the mystery is clear, the engine is damaged in cyl.nr.3.
One inlet valve is burned so there is a big hole, and the other valve is on the way.So now I have ordered a new used engine, will come to me last of week
so I can put it in the car in the weekend.
Regards Tommy
