So I was out one day and tooted my horn, It sounded but then sort of dropped slightly in pitch and failed completely. For a brief while all i did was disconnect the spade terminals, reconnect and the horn would work again. But sometimes only once or it was a very short beep.
I figured this was the end of that horn so bought a universal one online. Simple swap but when I plugged in the universal one I get no sound at all. Does the horn need to be grounded using the bracket that holds the horn to the car? or should the 2 cables connecting to the horn suffice in powering the horn?
Fuses are in tact, Relay clicks when the horn is pressed. Spade terminals replaced.
Ive checked with a multimeter. There is a Voltage difference of 12V between the 2 connectors on the horn when the horn is pressed. I checked for continuity with the old horn and there isn't so I can understand why that one doesn't work. The new one does have continuity but also doesn't work when hooked up to a lab DC powersupply (won't let me get to 12V though, as soon as I attach the croc clips the power supply jumps from 12V down to about 5V, the horn also got hot).
Any ideas? Have I just bought another duff horn? Thanks
