Hi all well i couldn't wait till the morning so took the stat of and well it dont look the best really i did test it in the hot water and it opened just fine but when it was time to close it did but there is a slight gap if that makes sense i put a touch on one side and you can see the light come through the other side is that normal for it to have a slight gap in them woooo and the gasket was hell of a mess to
if you have alook inside it,itwill have a seal, abit sandy coloured looking,
it will have perished,
these stats can fail in all differnt way's.
EG, over cooling ..noticed by temp gauge falling going down hill,
you can get the yo-yo effect too, (gauge up and down)
worst one is a stuck stat, it preasurises the system ..and weakest link is Headgasket,
clean the surface for the stat, wear gloves and clean off old sealant/gasket goo with a stanley blade. and paper gasket does the job,
RTV sealant seems good too,
Avoid cheap stat's dished out by car shops, buy good quality one ..only a couple of quid more, and it shouid last years, cheap ones can fail in weeks or months,
