Technical Jumpy and jerky running
Just reading over an old thread on here (2005), some chap did a compression test on his 99 1.2 16v and he said his 14mm didn't fit and that it was 12mm..maybe I should trust this fellow member from 9 years ago :D
Try Amazon then,
[ame="http://www.amazon.co.uk/Petrol-engine-automotive-compression-tester/dp/B00DS7P4WG"]Petrol engine automotive compression tester 10mm / 12mm / 14mm / 18mm 8pc AT351: Amazon.co.uk: DIY & Tools@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41mLvYWSNfL.@@AMEPARAM@@41mLvYWSNfL[/ame]
So tester due to arrive tomorrow, just thought I'd post up how I think I should perform the test (correct me when I'm wrong) :
Warm up the car to operating temp
Remove 4 sparks, thread tester into first spark hole (left side),
Turn the ignition on, fully press throttle in and crank for 5 cranks,
Mark out each 4 readings, repeat with 5ml of oil in each plug hole for wet test.
Now before you correct me I know that the fuel system and electrical needs to be disconnected to a certain point -- reason I haven't included as I'm not sure which way is the best: would I pull the fuse for the fuel system and pull wire from coil pack or can I disconnect the crank sensor, etc? :D
