- Aug 31, 2010
- 64
- 24
OK, generally around 48 to 52 MPG.
Clutch change. Broke one of the 3 cables in the lead on the O2 sensor below the catalyst but did not spot that as the lead was still connected..
After clutch change engine fault light on. Disconnected the top O2 sensor and it ran better. Ordered OBD2 reader and one O2 sensor.
Did the scan
130 O2 sensor 1 circuit malfunction (it was disconnected)
135 O2 sensor heater1 circuit malfunction
136 O2 sensor 2 circuit malfunction
141O2 sensor heater2 circuit malfunction
170 Fuel trim malfunction
Replaced O2 sensor 1, purchased a second O2 sensor and fitted that.
Fitted a new cam gasket.
Cleared all the fault codes.
Car has run like a dog since. 27 to 28 mpg and little power.
Engine fault light came on straight away again
Smells of petrol.
Just looking around and fitting yet another new air filter, not much appears to be wrong.
Any suggestions on where to start ? I think I will pull all the plugs first and have a look at their condition. I will report back. Might I have disturbed something in the ignition when changing the cam gasket ?
Frustrating ! It has been a fantastic car and I wanted to sell it after doing the clutch change, but I need to solve the problem first.
All four plugs pulled - all black as the ace of spades - definitely too much fuel entering each cylinder.
Did the scan
Smells of petrol.
