 - Aug 13, 2006
 - 3,246
 - 616
Since I was all a panic in the last thread and I have made some updates since, I'm starting a clean thread for my problem. I'm on the verge on scrapping the HGT and buying a very boring Hyundai i20 from my parents, but I want to give the car one more chance. Basically, the car stalls at idle until the engine is thoroughly warmed. From there, it performs faultlessly.
The problem was originally at intermediate temperatures, but seems to have spread to when the engine is cold too. I found the coolant temperature sensor to be slightly out of calibration, so this was replaced, but the issue is still there :bang: I disconnected the MAF to see if that improved things, but it didn't.
Now since I have an electronic throttle, presumably I don't have an Idle Control Valve, is that correct? It's almost as if the engine isn't holding its idle high enough during the warm-up phase. Interestingly, when I try to actuate the motorised throttle through MES, the procedure fails. Now I know that the throttle works, because it responds to the accelerator pedal, but is it possible that it is not responding to the additional inputs required of the ECU during warm up? Unfortunately, I don't know enough about the Hitachi MPI system to know what parameters and actuations it controls during warm-up.
I don't know if it helps, but the fault came on suddenly during very hot weather, it wasn't a gradual deterioration. Engine temperature was fine though (CTS was over-reading, so it would have been cooler than indicated by ~10%).
Cheers,
Mick
Cheers,
Mick
